In my car, Marea 1.8, '99, is 2nd version of ECU. It's supported in latest version FES. But...
When I trying to connect with ECU, there is a problem... FES can't connect (airbag and ABS works fine)
When I scanning, I have that message:
VAG-KKL interface + 3 pin adapter, Windows XP SP3.
GND on 3-pin interface (in car) is ok, also K-line...
I was trying with many difrent drivers and configurations....
What's wrong? My car is not supported in FES?
Best regards
Math
HITACHI MFi-018 support?
Re: HITACHI MFi-018 support?
Hello everyone.
I kept trying to connect to my ecu but no luck. I can communicate with the ABS an airbag so the cable is ok.
Now I have a imobiliser problem and want to get the full version to try and fix it but I can't communicate with ecu.
Do you happen to know if the pinout for the Hitachi MFI is the same as the MPI one?
All the best, Cristi
Anyone around here???
In which car mate?
It's a 1996 1800cc 16V Fiat Coupe.
I've tried all the list of ECUs in fiat ecu scan and not connecting.
The cable is ok I think as I can communicate with abs.
Still no luck with the airbag and the ECU!
Any support yet?
Please do the following:
1. Connect the cables to the 3-pin connector of the engine ECU
2. Execute the SCAN function
3. Try to connect by selecting "Hitachi MPI injection" from Coupe'96 1.8 16V
4. Click the red Send Report button to send me a report about the connection
5. Give me the date/time when you sent the report
I will check the report to see if there is any response from the control module.
OK. Will try tomorrow and send the report.yani wrote:Please do the following:
Many thanks in advance.
All the best,
Cristi
