fiat340
Post by fiat340 »
My ELM327 works great with engine but i can't connect to the CAN bus.
I have found de resistor R04 (121) (red marked) is this the right one, or maybe the resistor R14 (681).
http://postimage.org/image/9du31aqzt/
If the chip C4 is the term MCP2551
Then the red-marked resistor R04, which is must be removed.
lutxana1964
Post by lutxana1964 »
Hello, I´m new in this forum, I want connect with software TORQUE and my car is Nissan N16
I have a ELM327 bluetooth 1.4 same this that the user DJBASE ( I don´t know upload the picture) and i can´t conect with the ECU, the bluetooth is conected and the led red is light. Can you help me?
Hello Lutxana1964
Unfortunately, I can help you with your problem, because it is not always safe
whether a general diagnostic software also connects to each vehicle.
Especially French cars have so many problems
You've got to be the first to find out whether Torque also compatible with your N16 is
lutxana1964
Alfaeddy wrote:Hello Lutxana1964
In other forums they said that the TORQUE is compatible con Nissan N16 and they are coneted with the ELM327, I think that the problem is my ELM327.
I have got 5 led´s and only is light on the red and is starting the led last green but the others no.
Best regards,
fiat340
Post by fiat340 »
Yes the chip U4 is the MCP2551. I have removed R04 now and its works thanks!!
lutxana1964
[img]C:\IMAG0026.jpg[/img][img]C:\IMAG0027.jpg[/img]
can you say like upload an image.
I liked the order to insert a picture
Have you installed an app for your ELM interface FTDI drivers?
Upload attachmend.jpg (114.29 KiB) Viewed 8234 times
lutxana1964
Hi, This is my ELM327, do you think that i hate to removed the R04 ?.
Best regards.
Hello Lutxana1964
The problem of resistor is often described here is relevant only Multiecuscan, I have not heard of the other diagnostic software have problems with.
Otherwise, it is a different problem
Furthermore, this problem is not to find resistor to your ELM interface.
And the red LED will only show that the interface is receiving power.
the other LEDs flash only when transferring data
Sorry I can not help you.
