Nice that it works now. :-)
Why your first ELM does not work I can not say.
But I've had at least 15 different ELM interface from all over the world
All of them have worked so far, either immediately or after removing a resistor either R04 or R14 depending on the interface
Have fun with your interface and Multiecuscan
cmiro
Post by cmiro »
hi , im from serbia :D i have problem with ELM 327 and proxy all....
My elm :
problem:
http://www.youtube.com/watch?feature=pl ... Uc-deN2Rls
thanxx :)
The connection to your control you've made​​.
Therefore is not your problem, the ELM interface but another
probably a faulty control or the connection is missing then the
the proxy can not be executed.
Because you've got a connection
fabio25
Post by fabio25 »
Hello to everyone . I read all the messages but I can't find a fix to my problem ... Multiecuscan (and multiecuscan) can't see my ELM , I can not find it .I have the ELM on COM 5 but when I search it with multiecuscan the only thing I find is my modem ?!?!? on COM 7 . I have a fiat croma diesel from 2005 and the ELM works , I tested with another software ( i don't know if i can say the name here ...PPSCAN) Thank you
This interface we described here many times.
It does not have the abusive resistor
Have you ever loaded the new FTDI driver
fabio25
Post by fabio25 »
Hi . Yes , I have 2.08.24 on windows 7 . I tested the ELM with 3 different software and is working . With multiecuscan and multiecuscan I can't find it .
fabio25
Post by fabio25 »
When I search the ELM on COM 5 I get connection timeout . If a make auto search he finds my modem on COM 7 ?!? Thanks for your help Eddy
The fax modem on port 7 is an error your ELM is not recognized correctly.
And thus it makes Windows a fax modem
The drivers you have installed
- The interface to register once on a different COM port
- Ask the latency time to 1 (instead of 16)
- In the ELM Multiecuscan sign on your amended COM port? to
- Plug your interface into the OBD socket
- Switch on the dashboard lights
- Press F10 Connect
fabio25
Post by fabio25 »
Hi Eddy ,
Thank you for your advices , now is working just fine .
Best regards from Italy
Hello Fabio
Very often, the error setting
I am glad that your interface now works.
