LATENCY on old serial non USB cables
Boris
Post by Boris »
Does latency problem exists also on old only serial VAG-COM cables or it is a problem ony on newer VAG-COM USB cables?
Re: LATENCY on old serial non USB cables
If it is going to be any help for you...
I have one cable which is old at least 2 years and the other one which I bought few months ago...
On all two of them I have latency problem...
Boris
Post by Boris »
But both of them are USB?
Yes! ;)
Boris
Post by Boris »
Treba mi informacija da li obican serial ima tih problema, dok se jos da nabaviti...
Izvini drug, tek sam sada skontao da tebi treba info za KKL sa serial portom... :roll:
Boris
Post by Boris »
Nema problema :)
Ma poludio sam sa starim Motronikom od 164 2.0 V6 TB od Stanka sa foruma, stalno me odspajao, pa sam mislio da možda stari KKL sa serialom nema latency problem.. na kraju sam se ipak uspio spojiti na duze vrijeme.
Super! Drago mi je da si na kraju uspijeo i da je sve OK!
I ja imam isti problem na nekim modelima... ili sa nekim ECUima...
npr. kada spajam sa instr. tablom - navigator/ siemens na 166icama uvijek me izbaci nakon 20 sekundi...
nikad nisam imao vremena da istestiram taj latency problem... znam da se nesto moze srediti u postavkama, ali nisam pokusavao...
