Master123
Post by Master123 »
Thank you Alfaeddy, I will try to remove that part and I will let you know.
Regrads
Remove nothing
Make a picture of this place
Your ELM is the same as here on Alba_Skye
this did not interfere with this resistance of the CAN connection
compare it some
viewtopic.php?f=5&t=1493&start=120
There fore your ELM work without rebuilding.
Master123
Post by Master123 »
Yes, it is same as Alba_Skye. OK.
albyxj
Post by albyxj »
qualcuno sa dirmi perchè non va questa elm? non funziona con nessun programma . ho tolto anche la R04 ma niente. scantool non la riconosce ,
FES mi dice che è una versione 1.0 e che non si collegherà a nessuna linea CAN.
forse perchè è rossa?
:lol:
The reading of the data is very time critical, and the resistance between the two
CAN Cables changes time
Why this interface with other software but do not function with Multiecuscan (multiecuscan), I can not say exactly.
Anyway, the poor resistance R04 still present on your board.
The yellow circle sits the R04
DSCN6958 markiert.jpg (464.61 KiB) Viewed 9461 times
albyxj
Post by albyxj »
Alfaeddy wrote:Hello
grazie Alfaeddy la reistenza è eliminata ma il problema non credo sia quello.
si può provare a fare la modifica di Yani cambiando le altre resistenze o forse è un problema del chip?
stilo1.6
Post by stilo1.6 »
Hi I have the red version is
R04 removed
removed r14
CANbus network can not see does not work.
What is the solution can anyone answer?
Krg
Post by Krg »
I think if you remove R04, you must add the sets R32/R33 C8/C9
stilo1.6
Post by stilo1.6 »
Krg wrote:I think if you remove R04, you must add the sets R32/R33 C8/C9
Thank you very much KRG but unfortunately I can not be connected from the image. Can you help me because they are not in the same box. Mine v1.4
