Hello all
I have bought this cable http://www.ufodiag.com/pid10652353/VAG+COM+8124.htm
can i modify it to alfa romeo?
Reqard
Ronny
Usb obd2
Re: Usb obd2
ronny85 wrote:Hello all
Reqard
Ronny
Hello ronny 85, you must not take this, but you need the vag 409.1 KKL USB, then you can edit, but if you see this arcomento been talking a lot and see in the forum (viewtopic.php? f = 5 & t = 255)
then it depends who you need to alfa romeo 327 and elm also change, but at this point I suggest you you buy the multiecuscan 1.0 Multiplexed
regards
aron96
Re: Usb obd2
HELLO TO ALL MEMBERS WHY MULTIECUSCAN NOT SUPPORT KEY PROGRMMING?
Re: Usb obd2
Ok thx. i will try. Because i have this cable, (not that kkl) but i have bougt a cable(se my post before this post)
Re: Usb obd2
It has been discussed before...HASSAN wrote:HELLO TO ALL MEMBERS WHY MULTIECUSCAN NOT SUPPORT KEY PROGRMMING?
Yani does not want to add this option for saving/ deleting keys because people will easily delete some keys and the keys are very expensive… You can only get keys from official dealer.
You can ask it from Yani but I do not thing you will get it.
There are other programmers and softwares that have that option…
Re: Usb obd2
Aron96 is right. You need USB VAG COM KKL 409.1 cable for Alfa Romeo...ronny85 wrote:Ok thx. i will try. Because i have this cable, (not that kkl) but i have bougt a cable(se my post before this post)
