Alfa 159 3-zone climate control
I'm experimenting with different options for Alfa 159 and thought about converting a 2-zone climate control to 3-zone climate control. The system is the same and the only thing that appears to be missing is the rear control module.
I know how to activate the rear climate control unit now. I will experiment with adding the rear control unit and see if it works or requires additional components.
Anyone interested in this functionality?
pino_pino
Re: Alfa 159 3-zone climate control
Post by pino_pino »
Yani, already on 159ownersclub.it!
http://www.159ownersclub.it/public/foru ... 26#M361052
You need the 3-zone controller and actuator 52408227/00 EAB513 ;-)
Unfortunately, the information on the Italian forum is NOT correct.
The actuator "52408227/00 EAB513" is the PASSENGER side mixing actuator. The missing actuator is for DRIVER side!!!
I don't know the correct number of the missing actuator yet. Will post info when I find it.
