Information about Uconnect 7 without NAV
barto46
Post by barto46 »
Hello guys, I ask for your help on this model.
Continental Fiat 312 7 vp2 EMEA year 2018
MODEL:VP2RFP
FCA PN:07256831260
SW-VERSION:22.00.63.01
HW:F.EU.D5.V25
It has a GPS antenna: But it does not have navigation installed
#: I understand that this model can be activated navigation and then updated with new firmware, please correct me if it is correct or not
1: Can Carplay be activated on this model?
I hope your help on this model
Thank you
davidino66
Re: Information about Uconnect 7 without NAV
Post by davidino66 »
As far as I'm concerned, the answer is no to all questions
barto46
Post by barto46 »
Hello Davidino66, thanks for answering
So, this model is only radio, without NAV, without A/A? and GPS is only for synchronizing the time???
Please can you help me with other questions if you know
#:This model has 2 memories, one which is eMMC 1Gb where it should be NAV and Nand MT29F8G which has 8Gb with equipment firmware
Why do you have EMMC active on the unused device?? (when entering engineering mode it shows that it has active memory of LS CAN 1 Gb NAND)
#:I want to adapt this model to Body Computer Fiat 500L 2018
Entertainment Telematic Node(ETM)
What Bit do I have to change? if you can help me
33 31 33 33 30 30 30 37 35 37 38 4F 55 54 50 55 54 2D 53 49 54 20 13 12 16 01 00 00 00 02 00 00 00 01 00 00 00 00 7 C5 71 07 8F 02 37 10 31 00 00 06 00 07 08 8C 06 0B 01 46 C0 00 B1 01 35 41 0A 0C 0D 00 00 00 35 00 00 00 00 32 00 21 03 10 23 12 00 74 20 05 05 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B1 00 00 00 00 00 00 81 12 00 10 00 00 00 40 00 01 00 00 00 00 00 00 01 00 00 00
Thank you
davidino66
GPS is only for synchronizing the time, and for Compass data (show N/S/O/E... on display)
eMMC 1Gb contain operating system, and and Nand MT29F8G all the other data (NAV, CAR menu..)
I have no idea which bytes to change.. With MES it is relatively simple.. There are all configuration options available
barto46
Post by barto46 »
Thanks for helping with my questions
Now I'm looking for how to change the Bit with MES
Thank you
