Autoclose on FIAT TIPO (2015->) 1.6 131CV
Posted: 07 Dec 2023, 15:01
by GabryJ84
Good Morning,
I am in the process of receiving multiecuscan+connector purchased on the Italian distributor, but I have a question.
Among other features I will be implementing in my car, which are present in the software, there is one I can't find anywhere.
The feature is the "Autoclose" function, that activates automatic locking of the doors with speed above 20Km/h. This feature does not appear in all of the versions of FIAT Tipo, but on some forums there are already people that say that there IS.
Therefore, there should be some settings in the proxy file that enable or disable this function along with some other bytes that show in the UCONNECT the check (in the door menu) to enable/disable the feature.
Is anybody able to help with this issue?
Re: Autoclose on FIAT TIPO (2015->) 1.6 131CV
Posted: 07 Dec 2023, 17:23
On most Fiats since 2005 the Autoclose feature is in the vehicles setup menu and therefore not really needed as specific support in MES or other diagnostic software.
Check your Tipo's setup menus. With the 2015 onwards model then some settings will be in your uConnect system and others on the dashboard setting menu.
Posted: 07 Dec 2023, 18:03
by GabryJ84
s130 wrote: 07 Dec 2023, 17:23 On most Fiats since 2005 the Autoclose feature is in the vehicles setup menu and therefore not really needed as specific support in MES or other diagnostic software.
Should be in the UConnect...but does not show up under the "doors" menu. It seems it has been hidden and the only way to enable it is by manually modifying the bytes in the proxi...
Posted: 08 Dec 2023, 09:07
by shpuncik
paste your proxi log
