USA Stelvio 2019 cannot reset oil change
marcellino
Post by marcellino »
Hello all, I have a registered version of MES, connecting with a high speed OBDLinkSX. Everything is fine and dandy when I go to Service --> Service Interval Reset --> Connect --> Adjustments --> Next Service Reset. When I Execute I press Y I get an error and the oil change doesn't reset.
Anybody point me to where I'm going wrong? Or if there's a patch I need to download?
Thank you!
Re: USA Stelvio 2019 cannot reset oil change
Check in the engine ECU and not the Service node. If you have a diesel Stelvio then the Oil Change Reset is on the engine ECU Adjustments.
Also note that there are only 9 service coupons by default so after the 9th service the service reset will not work unless to reset the coupons as well.
marcellino
I don't have a the diesel Stelvio (I wish they had them here in the US.. but that's another story)..
Nevertheless, I tried Engine --> Magneti Marelli IAW 10JA CF6/EOBD Injection (2.0) --> Connect --> Adjustments --> Oil Change --> Execute --> wait 60s and nothing changed.
I also went back to the Service --> Interval Reset. I read the Service Coupons and they are 6. Nevertheless I tried changing that to a zero or a two, same error (FAILED TO EXECUTE).
If it can help in any way, I have Multiecuscan 5.1 REGISTERED and OBDLink SX.
Thank you
Being a 2019 Stelvio you probsbly have the "Security Gateway" (SGW) on your car. This blocks all write operations.
See: https://www.alfaobd.com/
If you do an MES SCAN it will list the SGW if it is present.
