Fiat tipo 2018 Cruise control retrofit
Alexpiu
Post by Alexpiu »
Hello everyone!
I recently had a friend come to me for a Cruise control activation on a Fiat tipo 2018 1.4.. The car came without one and he put a second hand steering wheel with buttons and wiring. The problem is that i activate the option with MES but it stil doesn't work. The CC buttons on the steering wheel light up for a few seconds when putting The ignition in ON position, then they go off.
Also, i get proxy allignment errors for the airbag node NAB ORC Request put of range error.
Anybody know how can i work this through?
abarthmultijet
Re: Fiat tipo 2018 Cruise control retrofit
Post by abarthmultijet »
Had a similar problem when I send my ecu out to get remapped. I could activate it with ignition on and the screen said: Cruise control activated.
Send the ecu back to them and they fixed it right away. I think your engine ecu needs to be programmed also.
chrener
Post by chrener »
HI!
Bodycomputer on Fiat Tipo signed with L0 does not support cuise control!
If you want CC just swap BCM with L1 or L2
