Jeep Renegade Proxi fail
OFF.PAVAN
Post by OFF.PAVAN »
HI, i try to activate a rearcam on a reengade 1.6 diesel, all works buts km are flashing and the eol of TCM is NOT OK, I trywith a different diagnisis tools (ESI, Autel and TExa) but evry fail on TCM, if is possible I want to set manual bite to stop fashing km because all works good, but still flashing
CAN CONFIGURATION DATA:
4F 0C 40 45 10 02 04 02 02 00 00 00 00 00 01 00 4F 0C 40 45 10 02 04 02 02 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00
4F 0C 40 45 10 02 04 02 02 00 00 00 00 00 01 00 4F 0C 40 45 10 00 04 02 02 00 00 00 00 00 00 00 4F 0C 40 45 10 02 04 02 02 00 00 00 00 00 00 00 4F 0C 40 45 10 00 04 02 02 00 00 00 00 00 00 00 4F 0C 40 45 10 00 04 02 02 00 00 00 00 00 00 00
33 38 36 30 39 32 31 36 38 33 38 4F 55 54 50 55 54 2D 53 49 54 20 18 07 19 4F 0C 40 45 10 02 04 02 02 00 00 00 00 00 01 00 4F 0C 40 45 10 00 04 02 02 00 00 00 00 00 00 00 D3 FA 2C 02 A8 83 08 64 51 2E 08 07 40 10 10 01 A3 28 14 92 81 35 73 14 01 4F 03 B4 9A 83 88 00 13 00 05 00 A6 00 0E F9 00 00 18 23 00 21 09 55 EB 64 02 AD 00 52 00 01 21 14 00 C0 94 01 00 C3 01 97 04 13 2A 00 49 02 0A 14 49 43 01 4B 00 01 00 80 10 20 04 27 9A 11 20 22 00 00 00 00 00 00 00 00 00 01 0A C0 01 03 82 00 01 00 00 02 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Body Computer (BCM/NBC)
Controllo motore (ECM/NCM)
Quadro Strumenti (IPC/NQS)
Cambio Automatico/Robotiz. (TCM/NCA/NCR)
Nodo Selettore Cambio (ESM/GSM/NSC)
Driver Assistant System Node (DASM)
Radio Frequency Hub Node (RFHM)
Security Gateway Module (SGW)
Climatizzatore (HVAC/NCL)
Rear Right Climate Control Node (RRCM)
Integrated Center Stack Node (ICS)
Guida Elettrica (EPS/NGE)
Impianto frenante (ABS/BSM/NFR)
Nodo Sensore Parcheggio (PAM/NSP)
Nodo Air Bag (NAB/ORC)
Nodo Controllo Corsia (HALF)
(Multiecuscan 5.1)
12/10/2023 08:33:11
Jeep Renegade 1.6 Multijet 16V
CAN Setup / PROXI Alignment Procedure (BU)
Controllo motore (ECM/NCM): EOL Ok
Quadro Strumenti (IPC/NQS): EOL Ok
Cambio Automatico/Robotiz. (TCM/NCA/NCR): EOL Ok
Nodo Selettore Cambio (ESM/GSM/NSC): EOL Ok
Driver Assistant System Node (DASM): EOL Ok
Security Gateway Module (SGW): Rimosso
Climatizzatore (HVAC/NCL): EOL Ok
Rear Right Climate Control Node (RRCM): Ok
Integrated Center Stack Node (ICS): EOL Ok
Guida Elettrica (EPS/NGE): EOL Ok
Impianto frenante (ABS/BSM/NFR): EOL Ok
Nodo Sensore Parcheggio (PAM/NSP): EOL Ok
Nodo Air Bag (NAB/ORC): EOL Ok
Nodo Controllo Corsia (HALF): EOL Ok
ESECUZIONE ADEGUAMENTO...
Telecamera posteriore
Vecchio valore: Non presente
Nuovo valore: Presente
COMPLETATO
PROCEDURA ALLINEAMENTO PROXI
Scrittura dati configurazione CAN...
Registrazione modulo: Body Computer (BCM/NBC) ESEGUITO!
Registrazione modulo: Controllo motore (ECM/NCM) ESEGUITO!
Registrazione modulo: Quadro Strumenti (IPC/NQS) ESEGUITO!
Registrazione modulo: Cambio Automatico/Robotiz. (TCM/NCA/NCR) ESEGUITO!
Registrazione modulo: Nodo Selettore Cambio (ESM/GSM/NSC) ESEGUITO!
Registrazione modulo: Driver Assistant System Node (DASM) ESEGUITO!
Registrazione modulo: Radio Frequency Hub Node (RFHM) ESEGUITO!
Registrazione modulo: Climatizzatore (HVAC/NCL) ESEGUITO!
Registrazione modulo: Entertainment Telematic Node (ETM) ESEGUITO!
Registrazione modulo: Integrated Center Stack Node (ICS) ESEGUITO!
Registrazione modulo: Guida Elettrica (EPS/NGE) ESEGUITO!
Registrazione modulo: Impianto frenante (ABS/BSM/NFR) ESEGUITO!
Registrazione modulo: Nodo Sensore Parcheggio (PAM/NSP) ESEGUITO!
Registrazione modulo: Nodo Air Bag (NAB/ORC) ESEGUITO!
Registrazione modulo: Nodo Controllo Corsia (HALF) ESEGUITO!
COMPLETATO
0=1989,1802,1872,1804
1=1989,1804,1809
2=1989,1988
3=1807,1806
4=0
5=0
6=0
7=0
8=0
9=0
Cambio Automatico/Robotiz. (TCM/NCA/NCR): EOL Fallito
chrener
Re: Jeep Renegade Proxi fail
Post by chrener »
Hi!
How did you activate RVC? Because configuration is without RVC... Which byte did you set?
OFF.PAVAN
Post by OFF.PAVAN »
chrener wrote: 17 Oct 2023, 20:47 Hi!
HI,
the car is without, i have used the menu drop down menù, I dindt know wich byte set
chrener
Post by chrener »
Load this:
33 38 36 30 39 32 31 36 38 33 38 4F 55 54 50 55 54 2D 53 49 54 20 18 07 19 4F 0C 40 45 10 02 04 02 02 00 00 00 00 00 01 00 4F 0C 40 45 10 00 04 02 02 00 00 00 00 00 00 00 D3 FA 2C 02 A8 83 08 64 51 2E 08 07 40 10 10 01 A3 28 14 92 81 35 73 14 01 4F 03 B4 9B 83 88 00 13 00 05 00 A6 00 0E F9 00 00 18 23 00 21 09 55 EB 64 02 AD 00 52 00 01 21 14 00 C0 94 01 00 C3 01 97 04 13 2A 00 49 02 0A 14 49 43 01 4B 00 01 00 80 10 20 04 27 9A 11 20 22 00 00 00 00 00 00 00 00 00 01 0A C0 01 03 82 00 01 00 00 02 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
OFF.PAVAN
Post by OFF.PAVAN »
chrener wrote: 29 Oct 2023, 09:51 Load this:
i have done the alliniment by Arbites and run without problem all module!
