Problem with power steering configuration reset fiat bravo
Roxy21
Post by Roxy21 »
Hi all...I wanted to know if someone could help me with a "power steering configuration reset" which ends with a function not performed in the power steering page...I need this function because I changed the steering column with a revised one with another configuration and I get the code C1103 but the power steering still works...thanks to everyone who can help me.
Re: Problem with power steering configuration reset fiat bravo
C1103 ABS Hydraulic Brake Switch Circuit Failure
When you put the steering column back are you sure you have reconnected all wiring and not broken anything? Do your brake lights work?
