how to change the TFT graph in 2016 abarth
sTeVenpOOn
Post by sTeVenpOOn »
Hi all, my 2016 abarth come with factory TFT display, the engine tachometer is display on the left side of TFT, can I change the graph to like 2018 abarth? their engine tachometer is bigger & display at the center of the TFT mon. Which byte should I change?
My Orginal 2016 Abarth (Made in Portland)
33 32 31 35 30 30 31 37 33 30 37 4F 55 54 50 55 54 44 4A 49 54 20 16 01 20 4F 84 00 05 02 00 00 00
09 00 00 04 02 00 00 00 91 C2 75 06 FE 00 1C A0 BA 80 00 16 00 01 00 94 06 01 01 00 00 00 00 40 79
41 0A 0C 0D 00 80 0E 23 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
02
fiatguy88
Re: how to change the TFT graph in 2016 abarth
Post by fiatguy88 »
Add this to the end of yours and tell me if that changes it
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
sTeVenpOOn
I will try it, thank you
sTeVenpOOn
Thank you man, I will try it later because Abarth is upgrading turbo in garage now
sTeVenpOOn
Sorry for my late reply, abarth is upgrading the tubo in guarge, after it's done, I will try it, will update to you asap, thank you so much for your help.
sTeVenpOOn
fiatguy88 wrote: 08 May 2023, 02:23 Add this to the end of yours and tell me if that changes it
I tired, cannot.
