Giulia MY23 proxy alignment
Marmotta
Post by Marmotta »
On Giulia 2.0 MY23 proxy alignment always fail on Airbag node (timeout), I use a elm327 1.4 and I able to connect to Airbag Ecu (no errors present)… What could be the problem?
Re: Giulia MY23 proxy alignment
have you tried to revert back race mode to it's original state and run proxi to see what happens?
Marmotta
Post by Marmotta »
No, not tried. That may be the problem?
Marmotta
Post by Marmotta »
I have testimony of another owner with the same problem, they after a travel of 600km he made it to align the proxy. Low battery? Sleeping Airbag ecu? …I try to charge the battery!
have you checked latency timer in device manager for adapter? some adapters don't like "1" so just set it to "2".
of course it could be some changes to MY23 model which MES currently isn't supporting. have you tried sending report back to support?
Marmotta
Post by Marmotta »
No way to do with multiecuscan, done with professional diagnostics
Marmotta
Post by Marmotta »
I have tried with a obdlink sx, all nodes are done… except Telematic box node (TBM). Is Strange, with elm327 I have a various issue with some nodes (and never align airbag) but TBM always work!
chrener
Post by chrener »
Do you have any seatbelt locked? Maybe its the cause of unsuccessfull proxi alignment on SRS unit.
Marmotta
Post by Marmotta »
chrener wrote: 21 Jul 2023, 11:48 Do you have any seatbelt locked? Maybe its the cause of unsuccessfull proxi alignment on SRS unit.
No seatbelt locked, I think is a bug with obdlink sx and mes5.1 on Giulia my23 proxy alignment.
Then send a log / report / Email to MES support. If a genuine issue then they will appreciate the report and information.
