Abarth 595 Uconnect 7 (Japan import) change locale?
kanada_green
Post by kanada_green »
Hi Everyone!
I have imported an official LHD Fiat Abarth from Japan to EU
and the following things really bug me)
-The FM station names don't display
-Only languages in the menu are English and Asian
-No DRL menu (can't turn off\on the DRL)
So I have been trying to do proxy allignemt with my uconnect 7 for the past few days
I have a 2020 Abarth 595 - manual, no sunroof, no cruise, no dusk, no rain sensors
carplay works, I have GPS but no NAVI and also the radio station name don't display
And I'm keeping getting an ETM error B222C-00
And when i do proxy allignment it says - ETM failed - request out of range error
Body Computer Delphi (312)
ISO Code: 00 00 60 15 14
Errors found:
B10AA-4A - PROXI configuration control
U1733-87 - Convergence Telematic Node (L1 and L2)
33 32 31 35 30 30 35 35 38 30 36 4F 55 54 50 55 54 44 4A 49 54 20 20 02 06 4F 04 00 05 02 00 00 00 09 00 00 04 02 00 00 00 81 C2 35 06 FE 00 1C C0 00 00 00 16 00 01 00 85 06 01 01 00 40 00 02 20 75 40 0A 0C 0D 01 80 2E 24 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8C 00 84 08 52 00 00 88 00 00 20 00 00 00 44 00 15 00 0F 00 00 00 80 05 00 80 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
can someone guide me in the right direction?
kanada_green
Re: Abarth 595 Uconnect 7 (Japan import) change locale?
anyone?
start from changing country code
kanada_green
shpuncik wrote: 04 Apr 2023, 20:17 start from changing country code
i have tried that, but nothing worked what byte is it?
byte #107
kanada_green
shpuncik wrote: 06 Apr 2023, 22:05byte #107
and what are the different country codes?
can you please help?
Also I was able to add the DRL menu, but it does nothing and the DRL now only work when I turn on low beams
MES shows you in proxi list of countries you can choose from
Edwin_Liu
Post by Edwin_Liu »
I have the same problem after I change to Uconnect7.
There isn't DRL function.
