Fiat Ducato 2017 airbag fault B0103-11
Therumrunners
Post by Therumrunners »
Reinstalled fixed airbag module and completed proxi alignment successfully. Cleared all the fault codes but have been left with this fault, B0103-11 Driver airbag resistance, short circuit to ground. Didn’t have that fault before the actual airbag module fault. Anybody any idea where best to look please? The motorhome hasn’t been used since November so is it possible a connection could be a bit cold and damp somewhere and might resolve itself when we start using the van again? Any thoughts gratefully received.
Re: Fiat Ducato 2017 airbag fault B0103-11
it's says about faulty circuit in driver's airbag. check steering wheel airbag connections, spiral cable.
Therumrunners
Thanks for the help
Therumrunners
Well, after some further advice, I bought a new airbag module from Coastal Motorhomes, fitted and now no alarms. So the repaired module still had faults on it. I do wonder whether it’s worth getting them ‘repaired’. I could have saved money by just buying a new one.
Thank you to the people that replied, it’s appreciated.
likely didn't repair it properly once again.
