Odometer flashing android radio
Posted: 27 Jan 2023, 23:36
by blackscell
Hi guys,
The problem I have is that I installed an aftermarket radio because the car came without one (theft) and since then the mileage is flashing. I have a new TFT screen, upped the mileage to the correct amount and did a proxy alignment. It fails due to an ETM error (radio). If I disconnect the radio it's alright but the moment I connect the radio it starts flashing. Any clue on how to fix this?
Re: Odometer flashing android radio
Posted: 27 Jan 2023, 23:52
by shpuncik
somehow car doesn't like your android radio CAN connection and detects it as new node hence blinking odo.
Posted: 27 Jan 2023, 23:54
by blackscell
Correct, but any way to fix it?
Posted: 28 Jan 2023, 00:15
by shpuncik
try asking seller. also usually radio under factory settings should have CAN bus settings for different cars. a lot of info can be found on android radios on 4pda or xda-developers forums.
but start with seller.
Posted: 28 Jan 2023, 00:29
by blackscell
shpuncik wrote: ↑28 Jan 2023, 00:15
Correct, mine is at 'Jeep_cherokee/renegade&FiatAegea(Simple);. Will contact seller see what he says, if anyone knows other canbus settings that I could try for the simple canbus let me know.
Posted: 30 Jan 2023, 08:39
by chrener
You have to set your radio type to type 1 and run proxialignment procedure... Your car set will be now on instrument cluster display...
Byte 111 set to 01
Posted: 09 Feb 2023, 02:02
by blackscell
Hi Chrener, thanks for your reply. I'm kinda new to MES, could you explain me how to change the byte?
