EPS calibration for newer verson of Delhi part
goforit
Post by goforit »
IS possible in newer version od MES to calibrate torque sensor of EPS (electric power system) in Delphi v2 system? I mean car like Grande Punto / Evo manufactured after 2009y. As well as Alfa Mito etc...
I have version MES 4.3 but there is error message when I try to calibrate torque sensor " Not proper conditions to make calibration" or something like this. There is no problem with older EPS column before 2009 with Delphi 1 software.
Re: EPS calibration for newer verson of Delhi part
you can always download latest version, install and run in simulation mode to see what options are available.
I can see on 4.8 there are torque and position sensor calibration options but I've not tried them.
goforit
Post by goforit »
This option is available also in very old version. Problem is that it cause error with message about not proper condition to make operation which is not true. And it happens only with newer cars with delphi v2 EPS column.
I have valid paid version 4.3 and do not want to pay another 50e just to this one test.
I will pay if I am sure it works properly.
then you'll have to wait. maybe someone else will respond because I've not done this procedure for a while and don't have way to test it
