Ducato 2013 changed gearbox
Posted: 03 Oct 2022, 23:20
by Danko
I have a Ducato 2.3 130hp 6 speed manual with replaced gearbox. Now the cruise control does not work, but the system does not have errors. Cruise only works in 5th gear. In 2, 3, 4, 6th gear ecu does not see the gear selected, only when I put it into 5th gear ecu manages to calculate current gear and enables the cruise.
Is there a way to change the gearbox ratios in ecu memory?
p.s. I'm licenced MES user, but I might have posted in wrong room.
Re: Ducato 2013 changed gearbox
Posted: 04 Oct 2022, 10:10
by chrener
Did you changed your transmission with same part number?
Main problem is in different gears ratio or in ECU adaptations..
Try to reset self-learning function in ECU
Posted: 08 Oct 2022, 17:01
by Danko
I tried everything I was able to try with MES, but no help. I dont know what gearbox is fitted, I did not swap it, it came to me to solve the cruise not working problem.
Posted: 08 Oct 2022, 20:45
by shpuncik
drop VIN number. original gearbox was also 6 speed?
