Cornering light Doblo 119
OFF.PAVAN
Post by OFF.PAVAN »
anybody know if is possible activate the cornering light on fiat doblo1.28v yera 2002 with this proxy:
34 36 38 34 32 30 35 36 20 20 20 54 45 52 4D 3A 30 34 20 20 20 20 01 11 24 0B 00 00 00 09 00 00 00 05 08 0C 01 03 18 29 07 00
Re: Cornering light Doblo 119
I highly doubt it's possible to have this feature on 119 Doblo
chrener
Post by chrener »
Hi!
Cornering lights works only on cars with Steering Angle Sensor Node. You can check it on Byte 27=10...
If it is present you can enable Cornering lights on Byte 42=20...
@chrener can't test now but I doubt you can enable it on 159 even though it has angle sensor. I think cornering lights were introduced somewhere around time Giulietta/Mito/500/Punto were released.
chrener
Post by chrener »
@shpuncik of course it depends on BCMs software...
But if its possible to set and it works on Croma, so why not on AR 159?
But byte setting is different...
OFF.PAVAN
Post by OFF.PAVAN »
Thanks a lot, i can do a try and text the result, i was surprise because it has the OEM followme light, when you turn off the car and press light arm the fog light turn on 30's, and increase the time how much time you press the armligth
