500X Proxy - Time out error
idlop
Post by idlop »
Hi there,
i have got some issues with latest MES and ELM327 1.4 Adapter from Electronic Fuchs bought with MES ....
First connection the adapter works fine and fast ---- every module is found ( i use the red cable to execute the SGW!! ) the second connection ist slow and not every module is found in the car.
Next issue is the Proxy Alignment : I receive many time out errors, the elm is installed "normal" and high speed .....so i hope someone can help me with the right configuration for the elm to do Proxy successfull.
The errors come with first and second connect to Proxy, i have all adapters i need for, but i do not complete successfull this proxy .....
thanks in advance
chris
Re: 500X Proxy - Time out error
check MES user manual for proper ELM327 setup in MES and Device manager
