First time user. It appears to work but.......
Trying to connect to my Engine Control Module. I select Magneti Marelli IAW 8GMK CF5/EOBD and get an Invalid ISO Code error stating that the module is returning an ISO code of IAW 8GMK CF5/EOBD which is what I selected. Hitting yes to continue appears to work. There is a message on the bottom about incorrect ISO code.
Don't know what i'm doing wrong. Using iDiagnostic ELM usb with windows 10. The built in Multiecuscan interface checks pass. The odd thing is I didn't have to install a driver when I plugged in my interface. However it is identified as properly functioning USB Serial Port in Device Manager.
Any insight would be appreciated.
