cp-aa on stelvio
OFF.PAVAN
cp-aa on stelvio
Post by OFF.PAVAN »
hi, anybody know how set on carplay \android on stelvio 2.2 with this proxy
CAN CONFIGURATION DATA:
4F 0C 40 65 10 02 18 02 22 08 00 00 80 00 01 00 4F 0C 40 65 10 02 18 02 22 08 00 00 80 00 00 00 00 00 40 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4F 0C 40 65 10 02 18 02 22 08 00 00 80 00 01 00 4B 0C 00 65 10 00 18 02 02 00 00 00 80 00 00 00 4F 0C 40 65 10 02 18 02 22 08 00 00 80 00 00 00 4B 0C 00 65 10 00 18 02 02 00 00 00 80 00 00 00 4B 0C 00 65 10 00 18 02 02 00 00 00 80 00 00 00
30 34 36 33 30 30 35 36 32 32 37 4F 55 54 50 55 54 2D 53 49 54 20 18 10 05 4F 0C 40 65 10 02 18 02 22 08 00 00 80 00 01 00 4B 0C 00 65 10 00 18 02 02 00 00 00 80 00 00 00 43 5D 27 02 A8 81 08 D4 24 31 A8 07 40 20 10 0A A3 28 04 F2 00 35 73 14 01 4F 03 34 1D 0B B0 24 1D 23 05 00 A0 00 0C C6 00 00 19 24 00 01 00 5E FA 64 06 ED 01 31 00 01 75 14 00 81 10 01 00 CB 00 B7 00 12 00 3D 49 02 03 12 F9 57 20 00 00 01 00 00 80 20 08 1A 89 0A 00 00 00 00 00 0C 94 00 00 00 40 B4 00 00 00 03 00 02 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
abarthmultijet
Re: cp-aa on stelvio
Post by abarthmultijet »
What is your proxy code?
Control alt c when in allignment tab.
OFF.PAVAN
Post by OFF.PAVAN »
Sorry
i dont know
what fuction is allignment tab?
the proxy copy is:
30 34 36 33 30 30 35 36 32 32 37 4F 55 54 50 55 54 2D 53 49 54 20 18 10 05 4F 0C 40 65 10 02 18 02 22 08 00 00 80 00 00 00 4B 0C 00 65 10 00 18 02 02 00 00 00 80 00 00 00 43 5D 27 02 A8 81 08 D4 24 31 A8 07 40 20 10 0A A3 28 04 F2 00 35 73 14 01 4F 03 34 1D 0B B0 24 1D 23 05 00 A0 00 0C C6 00 00 19 24 00 01 00 5E FA 64 06 ED 01 31 00 01 75 14 00 81 10 01 00 CB 00 B7 00 12 00 3D 49 02 03 12 F9 57 20 00 00 01 00 00 80 20 08 1A 89 0A 00 00 00 00 00 0C 94 00 00 00 40 B4 00 00 00 03 00 02 00 00 10 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
abarthmultijet
What kind of uconnect do you have?
OFF.PAVAN
Post by OFF.PAVAN »
the software is the A90 mv 090 000 061
chrener
Post by chrener »
May I ask you to share your modules list?
You can Copy them from FES Log file - its saved in MES main directory... File starts with proxi configuration code and then goes the modules applied in car...
THX
OFF.PAVAN
Post by OFF.PAVAN »
Body Computer (BCM/NBC)
Controllo motore (ECM/NCM)
Quadro Strumenti (IPC/NQS)
Cambio Automatico/Robotiz. (TCM/NCA/NCR)
Nodo Selettore Cambio (ESM/GSM/NSC)
Driver Assistant System Node (DASM)
Radio Frequency Hub Node (RFHM)
Security Gateway Module (SGW)
Climatizzatore (HVAC/NCL)
Rear Right Climate Control Node (RRCM)
Left Blind Spot Sensor Node (LBSS)
Right Blind Spot Sensor Node (RBSS)
Entertainment multimedia control module (EMCM)
Guida Elettrica (EPS/NGE)
Impianto frenante (ABS/BSM/NFR)
Nodo Sensore Parcheggio (PAM/NSP)
Nodo Air Bag (NAB/ORC)
Nodo Fari Autoadattativi (AFLS/NFA)
Nodo Controllo Corsia (HALF)
Power Lift Gate Node (PLGM)
(Multiecuscan 4.8)
14/03/2022 18:48:15
Alfa Romeo Stelvio 2.2 MultiJet 16V
CAN Setup / PROXI Alignment Procedure (949)
there is whole thread on the topic at:
https://www.giuliaforums.com/threads/updating-2017-models-to-android-auto-apple-carplay.46071/
chrener
Post by chrener »
Thanks!
