my Blue & Me module died so I wanted to remove it an do a Proxi, but encountered some errors.
Did someone else encounter a Airbag Node (NAB/ORC) FAILED! - Request out of range error Failed Proxi alligment with Multiecuscan v4.7r3 ?
->[102A] errors: Byte 69: 7C->4C
Is it fixed in v4.8 or is it another problem ?
Thanks!
Update : Situation is the same but after reading more about it I came to 2 conclusions... Or Multiecuscan 's range needs to be adjusted for the Airbag Node that it would allow 7C as byte 69, so the range needs to be set further from 4C.
Or I need to change 7C to another value... with the ALT+CTRL+C for custom proxi aligment... But which value ? Somewhere between 00 & 4C I presume... but which one ? As I do not understand why it has 7C as value...
Tried a friends multiecuscan v4.8 laptop and same problem :'(
Davide
CAN CONFIGURATION DATA:
4F 04 00 05 40 00 00 00 4F 04 00 05 40 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 40 00 00 00 00 00 00 00 00 00 00 00
4F 04 00 05 40 00 00 00 09 04 00 04 42 00 00 00 4F 04 00 05 40 00 00 00 09 04 00 04 42 00 00 00 09 04 00 04 40 00 00 00
30 34 31 39 31 30 30 37 35 36 36 4F 55 54 50 55 54 2D 4A 49 54 20 11 06 09 4F 04 00 05 40 00 00 00 09 04 00 04 42 00 00 00 C7 C5 51 07 8F 00 3C 10 38 00 00 36 00 07 0F 9C 06 2B 03 46 00 00 02 00 3A 51 0A 7C 00 00 00 00 09 00 00 00 00 37 03 91 00 38 00 40 00 00 00 04 08 00 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Parking Sensor Node (PAM/NSP)
Convergence Telematic Node (CTM)
(Multiecuscan 4.7R3)
3/03/2022 0:35:21
Alfa Romeo Giulietta 2.0 JTDm 16V
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Airbag Node (NAB/ORC) FAILED! - Request out of range error
Writing to module: Convergence Telematic Node (CTM) FAILED! - Timeout error
Writing to module: Receiver Radio/Radio Navigator Node (NRR/RMN) SUCCESS!
FAILED TO EXECUTE
