rear camera after uconnect swap
mokumaniak
Post by mokumaniak »
Hi all,
i will align the proxy on my 500x 1.4 140cv after uconnect swap (6.5 to7)
how to enable thev rear camera?
thank you 4 your help
chrener
Re: rear camera after uconnect swap
Post by chrener »
Check in engineering menu in RVC status if your U7 have RVC support...
Jeep Renegade 1.4 MultiAir TURBO 75th Anniversary
mokumaniak
thx look on this picture, in Engineering mode RVC config is in grey not in white
I can't go to the RVC config
Only basic Data (FW number)
https://1drv.ms/u/s!AhaD6GepAxliljvsCHN6GoGHNAIj?e=xPagop
mokumaniak
it's ok
my fiat 500X with uconnect 6.5
I brougth an uconnect 7 (version 500X 2020) with double USB (it's important) on Ebay.
When i mounted it on my 500X (2016)
Milage flash and rear camera have disappeared
With multiecuscan + blue and grey plug, i realign the proxy with a custom.......
My new Uconnect 7 works fine with activation of carplay.
arma500x
Post by arma500x »
anchio sono passato da uconnect 6.5 al 7 e solo la telecamera non compatibile con il 7 va cambiata
[S130 moderator]
I also switched from uconnect 6.5 to 7 and only the camera not compatible with the 7 should be changed‎
GS900
Post by GS900 »
mokumaniak wrote: 07 Feb 2022, 18:02 it's ok
Which custom Proxy do you installed, i have the Same Problem for my 500x 2015 1,4 Mulitair. Upgrade fromm Uconnect 5 to 7.
Thank You
