PDC Grande punto
nissanek_3
PDC Grande punto
Post by nissanek_3 »
I plan to add an original Valeo parking sensor module to my fiat grande punto. After connecting to the car's installation and to the CAN network, should the module work or do you need to activate it and perform proxy alignment? I do not see such a possibility in the proxy settings. You can help?
Re: PDC Grande punto
after installing module you'll need to perform proxi alignment. if PDC installed is front+rear you'll also need to do coding in proxi configuration.
