Fiat 500e 2016 cornering light
Sporting500e
Can some one tell me the byte or bytes to be changed for cornering lights on the fiat 500e 2016 usa model
abarthmultijet
Re: Fiat 500e 2016 cornering light
Have find this in forum archive: (for regular fiat 500)
Byte 58 -> 50 - cornering light
Byte 59 -> D9 - cornering light
regular Fiat 500 should use byte 42:
xx0xxxxx - without cornering lights
xx1xxxxx - with cornering lights
Sporting500e
read about hex/binary conversions.Sporting500e wrote: ↑18 Jan 2022, 10:52so i change byte 42 to 00 is no cornering light and byte 42 to 10 is with cornering light ??
mine byte 42 is now 80
if your byte 42 is "80" (hex) = "10000000" (bin) you change it to "A0" (hex) = "10100000" (bin)
PS sometimes cornering lights don't work, not sure why.
Sporting500e
Do you also know the byte to be changed for rvc in u connect 7shpuncik wrote: ↑18 Jan 2022, 11:06read about hex/binary conversions.Sporting500e wrote: ↑18 Jan 2022, 10:52so i change byte 42 to 00 is no cornering light and byte 42 to 10 is with cornering light ??
Sporting500e
When i change byte 42 into A0 also byte 121 changes from 44 into C4Sporting500e wrote: ↑18 Jan 2022, 10:52so i change byte 42 to 00 is no cornering light and byte 42 to 10 is with cornering light ??
alessandrosx
ciao, non puoi abilitare il cornering light sulla 500, perchè manca l'hardware
(By Mod) hello, you can not enable the cornering light on the 500, because the hardware is missing
