sound exaust
OFF.PAVAN
sound exaust
Post by OFF.PAVAN »
hi, I have a Alfa Stelvio Q4 2.9v6
and i want to set the exaust valve(only for hear the sound) on also open in the dynamic mode, now are open only in race mode
the valvle are drive by ecm slave-Nella parte terminale dello scarico è presente un by-pass che permette ai gas di scarico di essere inviatidirettamente verso l'uscita riducendo l'effetto del silenziatore tramite la elettrovalvola bypass L121 - collegataalla sola centralina Slave.
L’elettrovalvola L121, alimentata dall a linea del fusibile F22 di B001, vienecomandata da un segnale dal pin 39 del connettore C di M010
this is the proxy
30 34 36 33 30 30 31 31 38 37 38 4F 55 54 50 55 54 2D 53 49 54 20 17 11 07 4F 0C 40 65 10 40 19 02 2A 00 00 00 C0 09 00 00 4B 0C 00 65 10 40 19 02 0A 00 00 00 C0 09 00 00 43 5D 27 01 A9 81 08 D4 74 37 A8 07 40 20 10 0A A7 1E 04 72 00 35 73 14 01 4F 03 34 1D CB D4 48 23 43 05 00 81 00 0E 74 00 00 24 04 00 81 01 5E FA 64 06 E5 02 31 20 09 77 15 00 81 10 01 00 EB 00 B7 10 10 00 3D 49 04 03 12 F9 57 00 00 01 01 00 00 80 20 08 1A 81 0A 00 00 00 00 00 0E 56 00 00 00 40 B1 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
chrener
Re: sound exaust
Post by chrener »
Hi!
If its still actual,
If your exhaust flap actuator is operated by M010 - ECM than you will need to change setting in your Engine Contol Module, not proxi setting...
OFF.PAVAN
Re: sound exaust
Post by OFF.PAVAN »
I know, but i ask for somone have done the same experiment
