Scan 500L 500X 2018
mamomorris
Scan 500L 500X 2018
Post by mamomorris »
hi guys, i can't connect to these cars, i use the elm in picture, i read that there is something to do, but i can't understand, someone could explain me better. Thanks to those who want to help me. this is my ELM interface Image
Thanks to all.
mokumaniak
Re: Scan 500L 500X 2018
Post by mokumaniak »
Hello I had the same issue with a aliexpress cable, now i brougth one on a ebay french seller. It will arrive this week
abarthmultijet
Post by abarthmultijet »
Newer vehicles need a SGW Bypass,
https://alfissimo.com/home/1599-sgw-dongle-new-version-for-onboarddiagnostic-multiecuscan.html
arma500x
Post by arma500x »
bungiorno prima cosa prendere un tester cercare pin 6 e 14 misirare se avete una resistenza 150 hom circa bisogna smontare elm 327 individuare la resistenza e toglerla
linterfaccia va messa in alta velocita
poi provare se si riesce a entrare in tutte le interfaccie diversamente entra solo in controllo motore parlo 500x
le modifiche co sono nel forum magari non trovate linterfaccia uguale ma con un tester x pin 6 e 14
[S130 Moderator]
bungiorno first thing take a tester look for pin 6 and 14 misirare if you have a resistance about 150 hom you have to disassemble elm 327 identify the resistance and remove it‎
‎ the interface must be put in high speed‎
‎ then try if you can get into all the interfaces otherwise it only enters into engine control I speak 500x ‎
‎ the changes co are in the forum maybe you do not find the same interface but with a tester x pin 6 and 14‎
