ABS problem on Fiat Doblo (263) 1.6 MultiJet 120 KM DPF
Posted: 29 Nov 2021, 16:37
Welcome
I have a small problem, I am 2,000 km from my home and 400 km from the Fiat service station. I have Multiecuscan 4.8, AlfaOBD plus EML327 USB. Unfortunately, I am unable to deal with the following issue, which was not present before PROXI alignment.
ABS and ESP not working after PROXI alignment, error on the dashboard.
After proxy alignment in Multiecuscan v4.8 (purchased) the ABS driver showed 7 errors (previously there were no errors). After calibrating the longitudinal and transverse sensors, calibrating the steering angle and calibrating the pressure sensor, 1 error C1203-54 - Discharge/Charge solenoid valve.
PROXI alignment passes without error and ABS / ESP shows error.
Some LOG (copy-paste). If you need other logs, just let me know:
(Multiecuscan 4.8)
26.11.2021 17:23:39
Fiat Doblò (type 263) 1.6 Multijet 16V
Continental MK60EC ABS
ECU ISO code: EC 07 B5 0D 8A
FIAT drawing number: 52026221
Hardware number: 28561130013
Hardware version: A1
Software number: XD1BAA00083
Software version: 0000
Homologation number:
Functioning time (EEPROM): -1
Operating time: -1
READING ERROR CODES:
1. C1203-54 - Discharge/Charge solenoid valve
ERROR DETAILS: Missing calibration
Operating time: -1 min
Vehicle speed: 0,000 km/h
Battery voltage: 13,857 V
Brake pedal switch: OFF
Parking brake: OFF
Clutch pedal: Released
(Multiecuscan 4.8)
26.11.2021 17:23:39
Operating time: -1
Parking brake: OFF
