Cannot clear DTC on Ducato 290 Gearbox
Posted: 25 Aug 2021, 16:58
I am using a modified ELM327 adapter to communicate with a Ducato 290 2.3 Multijet van from 2020
Multiecuscan lists four systems (Engine, Gearbox, Body, ABS) without a yellow adapter, and additional systems with the yellow adapter.
Some of the systems report "ISO not recognised", but they appear to work correctly.
I can clear the DTC on the Engine, Body and ABS, and if I connect I can see values for the parameters.
When I connect to the gearbox I cannot clear the DTC and the parameters do not show values.
Scan DTC shows the following for the gearbox:
ZF 9HP48 Automatic Gearbox
ISO Code: 52 85 04 0D 3D
VIN code: ZFA25000002P38685
Hardware number: ES11-1065 D - Ver: 01
Software number: 68447579AH - Ver: 0001
Errors found:
U1400-00 - Accelerator pedal position (from NCM)
P1DD2-00 - Torque control (request)
U1424-00 - Error in communication with engine control unit (ECU)
U1408-00 - CAN line - connection with Braking System (NFR)
Does Multiecuscan support my gearbox?
Can I see the parameters for this gearbox?
Can I clear the DTCs?
Errors found:
