ECU type
ECU type
Does anybody know what ECU type has Stilo 1.6 from 2002 ??
Re: ECU type
Stilo 1.6 uses either IAW 5NF or IAW 5SF CF4.
Since your car is from 2002 I think it has IAW 5NF.
Unfortunately, none of these ECUs is supported in multiecuscan yet. Check for future versions.
Re: ECU type
Does anybody know what ECU type has the Alfa Romeo GT 1,9 JTDM 150 from 2007 and the FIAT Panda II 1,3 JTDM from 2008 ?
Re: ECU type
Alfa Romeo GT 1,9 JTDM 150 is probably EDC16/CF4.
FIAT Panda II 1,3 JTDM is either Marelli 6JF or Marelli 6F3.
Re: ECU type
In the Multiecuscan 1.4.1 System list there is EDC16/CF3 for the Alfa and Bosch ABS 8 for the Pandayani wrote: Alfa Romeo GT 1,9 JTDM 150 is probably EDC16/CF4.
Re: ECU type
I guess that EDC16/CF3 is for the earlier years. Since your car is from 2007 it should have EDC16/CF4.alfaGT wrote: In the Multiecuscan 1.4.1 System list there is EDC16/CF3 for the Alfa and Bosch ABS 8 for the Panda
It is ok to use ABS8 for the Panda, but it is for the ABS. For the engine you need Marelli 6JF or Marelli 6F3.
Re: ECU type
Ok thank you yani.
Re: ECU type
Hello yani,
please answer me, what ECU type has the Alfa Romeo 156 1,9 JTDM 150hp from 3/2005 ?
I'm testing ECU type EDC16/CF3, but shows this error : "Invalid ISO code for..."
Thx, Pablo
Thx, Pablo
Re: ECU type
your car is CF4 model not CF3
Re: ECU type
Bady, thanks for your answer, but are you sure ?bady555 wrote:your car is CF4 model not CF3
