Custom Proxy
jpp
Custom Proxy
Post by jpp »
I have a problem with Multiecuscan 4.6R1 on a Fiat 500 MY2019
I cannot edit the custom proxy
I go to the proxy alignment procedure, then I do "ctrl / Alt / C" but nothing happens
Is it possible that it does not work on some versions ?
Thank you
Re: Custom Proxy
check in your MES folder if there is FESLog file generated after you connect and disconnect to/from CAN Setup/Proxi and what is inside.
jpp
Re: Custom Proxy
Post by jpp »
yes ! ... I found plenty ... ;)
what is the reverse procedure, ie how to save in the ECU a FESLog file that has been modified?
thank you
Re: Custom Proxy
jpp wrote: 19 Apr 2021, 12:58 what is the reverse procedure, ie how to save in the ECU a FESLog file that has been modified?
through ctrl+alt+c
jpp
Re: Custom Proxy
Post by jpp »
OK,
What is the exact syntax for the upload file ?
Only one line for the proxy in a file called FESLog.txt ?
thanks
Re: Custom Proxy
jpp wrote: 20 Apr 2021, 07:20 OK,
thanks
you can't upload file. you can edit proxi just as you described. if it's not working then most likely not yet supported.
jpp
Re: Custom Proxy
Post by jpp »
I have the original proxy available in the first FESLog file (this proxy was OK no error and no problem)
I have changed in MES navigation: Not present ==> present
then Proxy alignment ==> Error (probablby because not supported)
Then back to Navigation : present ==> Not present
and then Proxy alignment ==> Error (don't undersant why)
Thus I would like to edit the proxy in order to return to the first configuration which was OK but with ctrl+alt+C nothing happen
and I d'ont know what to do
