KPH to MPH hex code
Shabs
KPH to MPH hex code
Post by Shabs »
I've been looking for weeks on end to find this fix and I'm coming to the point where I cannot use my 500
I had abarth tft dials in my 500 1.2pop
All worked fine, abarth start up, little white car showing as abarth etc
Mileage was flashing so I did a proxy alignment on it,.mileage stopped flashing but reverted the dials to a factory 500 tft style and the MPH changed to kph
I have managed to change the dials to abarth using the hex 60 code but the startup screen still shows 500 not abarth like it did before but the style after this is abarth yet the little car on the tft screen is not an abarth car just a standard 500 and I cannot get this car to go to MPH its driving me insane!! Please help before I burn it
Re: KPH to MPH hex code
I though all modern Fiats including the 500 could display either KM or MPH.
When using MES I seem to recall after messing around that my 500X reverted to KM after disconnecting MES. I just used the cars own menus/controls to switch back to MPH.
Suggest you check the user manual for the car and the uConnect.
Haxagon
Post by Haxagon »
I also need this Hex code, since proxy alignment of a tft conversion I only have KPH/KM's etc But want MPH and Miles back for UK driving.
Can't be changed using the car as have no menu in the TFT and no factory radio as it is a 2010 car.
A youtuber call 'Cars for Paul' got the code at the end of 2019.
Rob
