Airbag TRW2 (With pretensioners) 3 pin connection
L&MSpares
Post by L&MSpares »
I have a Alfa spider with a airbag fault. the airbag ecu is TRW2 (With pretensioners). i am struggling to connect to the airbag. every time I attempt to connect it says connection failure suitable interface not found.
can anyone point me to the right interface
Re: Airbag TRW2 (With pretensioners) 3 pin connection
The TRW2 with pretensions requires a VAG/KKL interface. ELM interfaces will not work.
See: https://www.multiecuscan.net/SupportedVehiclesList.aspx for your Spider Model. Will say [KL].
