Proxi Alignment failure Multiecuscan license 4.5
Nippy-ua
Post by Nippy-ua »
CAN CONFIGURATION DATA:
4D 84 40 05 01 00 02 00 4D 84 40 05 11 00 02 00 01 04 00 01 10 00 00 00 01 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00
4D 84 40 05 01 00 02 00 09 00 00 00 01 00 00 00 4D 84 40 05 11 00 02 00 09 00 00 00 11 00 00 00 09 00 00 00 11 00 00 00
31 36 31 32 32 39 35 31 38 30 30 31 32 33 34 35 36 37 38 39 30 20 16 07 18 4D 84 40 05 11 00 02 00 09 00 00 00 11 00 00 00 80 D0 4D 06 F4 40 01 70 0A 01 08 57 00 09 00 94 00 00 04 00 81 A3 10 00 00 00 00 00 00 02 00 00 27 00 29 00 00 35 06 C1 01 00 00 A0 00 00 00 00 30 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 A2 00 B0 98 52 10 00 D0 0A 00 B0 00 38 01 74 10 51 00 00 00 00 00 00 01 00 A0 01
Body Computer Node (BCM/NBC)
Dashboard Node (IPC/NQS)
Gearbox Selector Node (ESM/GSM/NSC)
Parking Sensor Node (PAM/NSP)
Airbag Node (NAB/ORC)
Tire Pressure Node (TPMS)
Vehicle Tracking Module (VTM)
(Multiecuscan 4.5)
09.03.2021 2:39:15
Fiat 500e EV
Climate Control Node (HVAC/NCL): Ok
Gearbox Selector Node (ESM/GSM/NSC): Ok
Parking Sensor Node (PAM/NSP): Ok
Airbag Node (NAB/ORC): Ok
Tire Pressure Node (TPMS): EOL Ok
Vehicle Tracking Module (VTM): Ok
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
Writing to module: Tire Pressure Node (TPMS) SUCCESS!
Writing to module: Entertainment Telematic Node (ETM) FAILED! - Unknown error
   [102A] errors: Byte 30: 11->01 | Byte 123: 51->59
FAILED TO EXECUTE
Re: Proxi Alignment failure Multiecuscan license 4.5
what are you trying to do? have you added new radio?
Nippy-ua
Post by Nippy-ua »
shpuncik wrote: 09 Mar 2021, 09:58 what are you trying to do? have you added new radio?
Hallo
I try to change the radio frequency
what changes have you done?
post your original proxi config before any changes have been made
Nippy-ua
Post by Nippy-ua »
shpuncik wrote: 10 Mar 2021, 09:59 what changes have you done?
how to save proxi config ?
thanks
Nippy-ua wrote: 12 Mar 2021, 23:25 how to save proxi config ?
thanks
they are always saved in MES folder when you connect to CAN Setup/Proxi
alex-et3
Post by alex-et3 »
Nippy-ua wrote: 09 Mar 2021, 21:17
Hallo
it s not possible, change the tuner inside the radio.
