Panda 2011 69 hp
GalA
Panda 2011 69 hp
Post by GalA »
Hi all!
I didnt find an answer to my question using search, So ill ask:
Does fiat panda euro5 (69 hp) 2011 included in the panda 2003 section or panda 2012 section?
Thanks,
Gal
GalA
Re: Panda 2011 69 hp
Post by GalA »
Ok, is the 2003.
But I have more questions...
I purchased the full softwear fot my panda, and I cant find some engine paremeters:
Coolant tem.
Stft (lambda sensor 1 integrator?)
Ltft (I cant find the equivalent of multiecuscan for this one).
For those who don't know all the variations of Panda and other models engine variations what is the engine size in cc and petrol or diesel?
Coolant Temp. = Engine Temp.
GalA
Post by GalA »
Petrol
1.2 L
The same engine as in the 500 (euro 5)
Thank you for the reply!
Do you have any idea about the Ltft? I was reading all night about the other options multiecuscan has to offer, but I couldnt find them... For example, I dont have the fra or dtv parameters, Or Mixture correction learning value (for long term fuel trim).
I want to cheak how efficient is my engine and I understand that I need to start from Ltft and Stft.
IF Someone has any other suggestions, I would like to know.
MY engine computer is magneti Marelli iaw 5sf
GalA
Post by GalA »
Edit:
Just to make my self clear: Im suspecting that my engine fuel economy is low, So I want to cheak if there is a added fuel to compensate some iregularities (e.g. Vacuum leak; the Ltft should be a goog measurement for this situation)
GalA
Post by GalA »
Bump
Some alternative for fuel trims?
