DRL Default setting
BigB24
DRL Default setting
Post by BigB24 »
Hi all,
Does anyone know whether it's possible to change the default parameters for the DRL lights? I.e always on rather than turning off with dipped/full beams?
I have some additional lighting wired into the DRLs that I would like to be always on.
Vehicle is: Abarth Punto Evo 1.4
Thanks!
Re: DRL Default setting
Can't comment on the technical setting options but would advise that in the UK and EU DRLs are legally required to DIM / reduce output or turn off when headlamps are turned on.
This being the case then unless the US/other world regions do not require the dimming/turning out of the DRLs then it is fairly unlikely that there is the ability to change this characteristic operation.
