4.7 Cannot connect to a 500L with SGW
antonionni
Post by antonionni »
Hi all
before buying a licence, I want to make sure it works with my 500L with SGW.
Now I try a free version (4.7) on W10, but it doesn't connect with a car.
I'm using this interface, which works well with others apps: https://www.veepeak.com/product/obdcheck-ble-plus/
Here an AT commands sends from another app, maybe it was a timing problems?
Last question: the licence is expiring after 1 year, or is valid for further upgrades, even if only for my car?
Many thanks and best regards
ECU1: Control module 0x18DAF110
ISO 15765-4 (CAN 29/500)
TIMESTAMP		DIRECTION	DATA
2020-12-24 20:28:11	>>		ATD
2020-12-24 20:28:12	>>		ATZ
2020-12-24 20:28:12	<<		ELM327 v2.2
2020-12-24 20:28:14	>>		ATI
2020-12-24 20:28:14	<<		ELM327 v2.2
2020-12-24 20:28:14	>>		AT@1
2020-12-24 20:28:14	<<		OBDII to RS232 Interpreter
2020-12-24 20:28:14	>>		AT@2
2020-12-24 20:28:14	<<		ÿÿÿÿÿÿÿÿÿÿÿÿ
2020-12-24 20:28:14	>>		ATE0
2020-12-24 20:28:14	<<		OK
2020-12-24 20:28:15	>>		ATL0
2020-12-24 20:28:15	<<		OK
2020-12-24 20:28:15	>>		ATS0
2020-12-24 20:28:15	>>		ATM0
2020-12-24 20:28:15	>>		ATST64
2020-12-24 20:28:16	>>		ATTP0
2020-12-24 20:28:16	<<		OK
2020-12-24 20:28:16	>>		0100
2020-12-24 20:28:22	<<		SEARCHING...18DAF110064100BE3EB813
2020-12-24 20:28:22	>>		ATDPN
2020-12-24 20:28:22	<<		A7
2020-12-24 20:28:22	<<		AUTO, ISO 15765-4 (CAN 29/500)
2020-12-24 20:28:22	>>		ATH1
2020-12-24 20:28:22	<<		OK
2020-12-24 20:28:22	>>		0100
2020-12-24 20:28:23	<<		18DAF110064100BE3EB813
2020-12-24 20:28:23	>>		0100
2020-12-24 20:28:23	>>		0120
2020-12-24 20:28:24	<<		18DAF11006412080078011
Re: 4.7 Cannot connect to a 500L with SGW
I can address the license issue.
Your license is valid for 1 year. During that year you will be entitled to all bug fixes and new released versions, e.g. 4.8.
After 1 year your software will continue to work on ALL MES listed/supported vehicles with no restrictions.
The 500L has been supported for several versions of MES so 500L support is pretty mature. This means that after a year your are probably not going to need to purchase a new license unless significant feature/support are added to MES for the 500L or you obtain another more recent vehicle.
Hope this helps.
antonionni
Ok, many thanks.
s130 wrote: 25 Dec 2020, 15:32 After 1 year your software will continue to work on ALL MES listed/supported vehicles with no restrictions.
Would just like to clarifiy that "ALL MES listed/supported vehicles with no restrictions" is retricted to those vehicles that were supported in the current release when your license expired.
antonionni wrote: 26 Dec 2020, 20:21 Ok, many thanks.
You are welcome.
I wish I could offer more information regarding your connection issues but I've never used a Blue Tooth adapter so am not qualified/experienced to offer definitive advice/information.
If no one else responds then you should contact MES Support.
antonionni
s130 wrote: 26 Dec 2020, 21:19
Yes, obviously.
As for the interface, I'll buy an USB one.
Many thanks again
