Mito MultiAir adaptation FAILED
Posted: 28 Oct 2020, 15:10
by merror
Hello, car Alfa Romeo Mito 2009r 1,4 tb 170HP
Multiecuscan 4,5
Activator MultiAir was repered (loose sleeve , car work for 3 cylinders and knock, no errors in ecu)
after repair I made adaptaion UniAir actuator dispersion correction and oil change, adaptation start rpm incrase to 1000rpm and after 20sek i gets info " DONE not OK"
check engine is flashing, engine works ok have power, dna work, multiair work only in full-lift, no errors
If I dont do this adaptation everything will be ok......
Please for help, sholud I buy new activator MA or how pass adaptation??
Re: Mito MultiAir adaptation FAILED
Posted: 22 Aug 2023, 23:24
by Oliverautomotiveltd
Old topic but I don't suppose you got too the bottom of this fault? I have the exact same symptom and looking for an answer as someone must of got over this issue before?
Many thanks
Luke
Posted: 24 Dec 2023, 13:21
by Maddogdom
I’m having exactly the same problem, can anyone help?
