Hi guys.
I recently purchased MultiECUscan to rectify a few issues with my van such as proxy realignment and activating Cruise Control.
I got an OEM stalk, plugged it in and activated it in the body control module. Now it works a treat. However the Cruise control light on the dash doesn't illuminate when cruise is active. If i go into actuators and switch it on manually the light is there and illuminates. However when actually using the cruise function in real world driving the light doesnt come on with the switch
Any ideas?
Is this missing a piece of coding?
Is there a way to activate it somewhere else in the settings?
Thanks.
Jay
Cruise Control LIGHT activation
Re: Cruise Control LIGHT activation
Sorry. I should have said. The van is a 2013 Facelift Citroen Relay (Fiat Ducato platform)
You did everything right. Second step: retrain the configuration in the SID208 ECU using Diagbox.
