Remove radionav from giulietta 2011
Posted: 07 Apr 2020, 21:02
by Andre@96
Hi, i removed the radionav from my giulietta MY2011 but the odo flash and the b&m don't work properly.
I do a proxy alignament but the procedure not completed correctly. this is the log file:
Lettura dati configurazione CAN...
CAN CONFIGURATION DATA:
4F 04 00 05 42 00 00 00 6F 04 00 05 02 00 00 00 03 00 00 00 42 00 00 00 01 00 00 00 42 00 00 00 00 00 00 00 00 00 00 00
4F 04 00 05 42 00 00 00 09 04 00 04 42 00 00 00 6F 04 00 05 02 00 00 00 09 04 00 04 42 00 00 00 09 04 00 04 02 00 00 00
30 34 31 39 31 30 30 33 32 38 38 4F 55 54 50 55 54 2D 4A 49 54 20 10 10 28 4F 04 00 05 42 00 00 00 09 04 00 04 42 00 00 00 C7 C5 51 07 8F 00 3C 20 B8 10 28 1E 00 07 05 BC 06 2B 03 46 40 00 02 00 3A 51 0A 7C 00 00 00 00 09 C4 00 00 00 37 01 E1 01 38 00 44
Body Computer (BCM/NBC)
Controllo motore (ECM/NCM)
Guida Elettrica (EPS/NGE)
Quadro Strumenti (IPC/NQS)
Radio Ricevitore (NRR)
Impianto frenante (ABS/BSM/NFR)
Climatizzatore (HVAC/NCL)
Nodo Sensore Parcheggio (PAM/NSP)
Nodo Air Bag (NAB/ORC)
Nodo convergence
Radio Ricevitore/Radio navigatore a mappe (NRR/RMN)
(Multiecuscan 4.6)
07/04/2020 22:35:41
Alfa Romeo Giulietta 2.0 JTDm 16V
Body Computer (BCM/NBC): EOL Ok
Controllo motore (ECM/NCM): Ok
Guida Elettrica (EPS/NGE): Ok
Quadro Strumenti (IPC/NQS): EOL Ok
Radio Ricevitore (NRR): Nuovo
Impianto frenante (ABS/BSM/NFR): Ok
Climatizzatore (HVAC/NCL): EOL Ok
Nodo Sensore Parcheggio (PAM/NSP): Ok
Nodo Air Bag (NAB/ORC): EOL Ok
Nodo convergence: EOL Ok
Radio Ricevitore/Radio navigatore a mappe (NRR/RMN): Rimosso
ESECUZIONE ADEGUAMENTO...
PROCEDURA ALLINEAMENTO PROXI
Scrittura dati configurazione CAN...
Registrazione modulo: Body Computer (BCM/NBC) ESEGUITO!
Registrazione modulo: Quadro Strumenti (IPC/NQS) ESEGUITO!
Registrazione modulo: Climatizzatore (HVAC/NCL) ESEGUITO!
Registrazione modulo: Nodo Air Bag (NAB/ORC) ESEGUITO!
Registrazione modulo: Nodo convergence ESEGUITO!
Registrazione modulo: Radio Ricevitore/Radio navigatore a mappe (NRR/RMN) FALLITO! - Errore tempo di attesa
ESECUZIONE FALLITA
how can i remove the radionav?
Re: Remove radionav from giulietta 2011
Posted: 11 Apr 2020, 22:02
by DiReCtX
I also had a problem with it but I dealt with it myself.
MES have bug with remove node with PROXY, like NAV, B&M..
You must change proxy byte manually.
Regards
Peter
Posted: 11 Apr 2020, 22:22
by Andre@96
Hi friend, thanks so much for your help and the PM with the correct proxy, after some hours with MES i take a proxy configuration from another giulietta with the same optionals and with a first allignament i solved the problem. :mrgreen:
Posted: 21 Apr 2020, 22:20
by DaveDevil
Andre@96 wrote: 11 Apr 2020, 22:22 Hi friend, thanks so much for your help and the PM with the correct proxy, after some hours with MES i take a proxy configuration from another giulietta with the same optionals and with a first allignament i solved the problem. :mrgreen:
Hi, can I ask you how you have solved this problem? I tried to align the proxy after removing my radionav, but it failed because he still tries to locate the radio module...
Posted: 23 Apr 2020, 08:52
by DiReCtX
DaveDevil wrote: 21 Apr 2020, 22:20
enter your proxy that you have via ctrl + alt + c, I will change the appropriate bytes for you
Regards
Posted: 09 May 2020, 13:03
by DaveDevil
Hello, Sorry I did not receive the notification to the reply, the mail gone in "spam" folder. Now I added the forum to the whitelist!
Here's my actual proxy:
30 34 31 39 31 30 30 38 38 33 36 4F 55 54 50 55 54 2D 4A 49 54 20 11 09 08 4F 0C 40 05 02 00 00 00 09 04 00 04 42 00 00 00 87 C5 51 07 8F 00 3C 21 B8 10 00 16 00 07 01 94 06 2D 03 3C 00 00 01 00 3A 51 0A 7C 00 00 00 00 09 00 00 00 00 36 01 61 01 38 00 20 00 00 00 04 06 00 00 00
thank you very much
