Fiat Tipo 2017/2018 service reset
Posted: 27 Jan 2020, 20:43
by erola
Is it possible somehow to reset service sign on Fiat Tipo 2017/2018 Without any tools? Tried procedure like oin Fiat500 (Igniotion On-> 3x Accelerator Pedal->Igniotion Off). But it does not work for Tipo.
At the end if it requires tool - could you please suggest which verison of Multiecuscan do I need for that job? Is it Free version of Multiecuscan enough?
Tony
Re: Fiat Tipo 2017/2018 service reset
Posted: 28 Jan 2020, 17:10
I'm fairly sure that the service/oil change can only be done/reset via software.
Check that your Tipo is a supported vehicle here: http://www.multiecuscan.net/SupportedVehiclesList.aspx
I know Tipo 2015 is supported but do not know if there have been any radical changes made by Fiat other than body styling and options etc. If not then Tipo 2015 will in effect be 2015+
You will need the paid for version as all the functions are listed in red.
