proxi alignment jeep compass 2017
Posted: 15 Jan 2020, 23:01
by miky355
anybody knows if is posible to do a proxi alignment on jeeps compass 2017 with muliecuscan 4.5?
Re: proxi alignment jeep compass 2017
Posted: 19 Jan 2020, 17:33
by chrener
Hi!,
yes it is possible, what you need to do with?
Posted: 22 Jan 2020, 12:04
by abiurrunc
Hi chrener, in my case, I want to be able rear Cam and other options. All guys in jeep furum are having issues to alignment their jeep compass from 2017.
Do you know what's the right process?
Do we have to changes our Elms to specific model?
Thanks in advanced and have a nice week.
Angel BC.
Posted: 28 Jan 2020, 11:44
by davidino66
Probably your Compass have the "secure gateway" (SGW). You have to bypass it for proxi alignement...
Posted: 30 Jan 2020, 10:01
by miky355
Hi!
as abiurrunc says we want to activate the rear camera and proxi alignment but it always gives me "timeout error" in the DASM module. the camera remains activated but the odometer is blinking due to the error of the DASM module. I do not think it has a secure gateway, because it is the 2017 model and I think that this system was implemented in 2018. I have tried with an elm327 special usb for jeep and multiecuscan bought in idiagnostic and also with an obdlink usb obtaining the same fault. Any ideas to correct the error in the DASM module?
Thanks a lot!
Posted: 20 Feb 2020, 09:19
by miky355
I have been able to activate the rear camera and it works fine, but when doing the proxi alignment there is always a "timeout error" in the DASM module and the odometer is blinking, and when I do fault scanning (F12) it only says that the ISO code of the DASM module is unknown
I use an obdlink usb with a speed of 115200, and the vehicle is a 2017 model, so it doesn't have a secure gateway (SGW).
any suggestions? THANKS!!!!
Posted: 22 Feb 2020, 10:03
by chrener
Do you have blue and grey adapter for connection to some modules? Without adapters you cant do the proxy alignment with ELM...
Posted: 26 Mar 2020, 13:06
by miky355
chrener wrote: ↑22 Feb 2020, 10:03
yes, of course
Posted: 02 Jun 2020, 16:19
by miky355
finaly i have fixed the problem with ALFAOBD software, wich has support for DASM module.
Posted: 23 Oct 2020, 21:40
by EZname
miky355 wrote: ↑02 Jun 2020, 16:19
I’m still having the same problem with my 2020 Jeep Compass 2.4L.. I’ve used alfaobd v2.2.2.0 but still not luck.. what did fit do to fix the blinking flashing ??
