Calibrating Alfa Giulia Airbag
sslimss
Post by sslimss »
Can anyone tell me where to find the program in multiecuscan to calibrate the Alfa Giulia airbag ? Thanks
Re: Calibrating Alfa Giulia Airbag
What do you mean by calibrate?
Currently on the Giulia air bag support in MES there are no "Actuators" and this is where any calibration or testing of air bag and pre-tensioner/seat belt indicators would be.
s130 wrote: 21 Dec 2019, 10:04 What do you mean by calibrate?
In technical service manual there is function to calibrate airbag module with witech. You have to do it when new airbag ECU is installed. Haven't tested it but my guess is you have to do it after you install used one too.
If ECU is not calibrated there is DTC which says something similar to "airbag module not calibrated" and airbag light stays on after ignition is switched on. It won't even blink as it normally does after 5s when ignition is switched on - just constant ON.
