Fiat Punto Evo not crank after Self-adaptation reset with Multiecuscan 4.5
Posted: 17 Nov 2019, 16:32
by sandmarino MultiEcu
Hi guys!
I have a problem with no cranking after I did: 1. Reset self-learning function, 2. Self-adaptation reset and 3. Phonic wheel learn with Multiecuscan 4.5 on my Fiat Punto Evo 1.2.
I had never had a problem with not cranking. Even before to execute those resets the car had started perfectly.
Would you suggest to me where the problem could be? The Multiscan software indicates that the battery voltage is 11.6V. Is it possible to be a problem or I did something wrong to the car ECU and there is no signal to the starter?
Thank you very much!
Re: Fiat Punto Evo not crank after Self-adaptation reset with Multiecuscan 4.5
Posted: 07 Sep 2024, 22:53
by Sweep165
Hi, I have the same problem. Did you find out what was wrong ?
Posted: 16 Sep 2024, 18:22
by abarthmultijet
Had the same problem with a Jeep Renegade 1.4 multiair once, what i ended up doing was a bump start with ignition on and then a phonic wheel learn. Everything was fine after that, no codes and a good running engine.
