Problem alignement proxy Jeep Renegade
LDalCol
Post by LDalCol »
HI, I change the climatization comtrol panel manul to automatic climatization panel.
I Try to do alignment proxy, but these error occurred, what I need to do? What is wrong?
Im using original OBDLink SX byed into oficial OBDLink site
(Multiecuscan 4.5)
18/10/2019 20:07:24
Jeep Renegade 2.0 Multijet 16V
Bosch EDC17C69 CF6/EOBD Diesel Injection (1.6, 2.0)
CAN CONFIGURATION DATA:
4F 0C 40 04 10 00 00 00 08 00 00 00 00 00 00 00 4F 0C 40 04 10 00 00 00 08 00 00 00 00 00 00 00 00 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00
4F 0C 40 04 10 00 00 00 08 00 00 00 00 00 00 00 4F 0C 40 04 10 00 00 00 08 00 00 00 00 00 00 00 4F 0C 40 04 10 00 00 00 08 00 00 00 00 00 00 00 4F 0C 40 04 10 00 00 00 08 00 00 00 00 00 00 00 4F 08 40 04 10 00 00 00 08 00 00 00 00 00 00 00
32 38 36 31 31 30 34 36 38 38 31 4F 55 54 50 55 54 2D 53 49 54 20 17 07 21 4F 0C 40 04 10 00 00 00 08 00 00 00 00 00 00 00 4F 0C 40 04 10 00 00 00 08 00 00 00 00 00 00 00 D2 E8 2C 02 AC 09 08 2A 80 33 08 07 59 10 20 06 A1 28 54 11 00 05 10 14 10 4F 03 B4 00 8B C0 00 8E 4B 06 00 AA 02 10 EE 00 00 20 04 00 01 00 58 A1 0F 02 BD 00 41 00 01 21 12 3D 52 00 01 03 C0 00 81 00 12 9E 00 00 B2 0A 32 DA 0A 00 00 00 01 00 00 28 20 00 00 82 40 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Body Computer (BCM/NBC)
Controle Motor (ECM/NCM)
Quadro de instrumentos (IPC/NQS)
Câmbio Automático (TCM/NCA/NCR)
Nó Seletor do Câmbio (ESM/GSM/NSC)
Drive Train Control Node (DTCM)
Climatizador de ar (HVAC/NCL)
Direção Elétrica (EPS/NGE)
Sistema dos freios (ABS/BSM/NFR)
Nó Air Bag (NAB/ORC)
(Multiecuscan 4.5)
18/10/2019 19:56:19
CAN Setup / PROXI Alignment Procedure (BU)
Controle Motor (ECM/NCM): EOL Ok
Quadro de instrumentos (IPC/NQS): EOL Ok
Câmbio Automático (TCM/NCA/NCR): EOL Ok
Nó Seletor do Câmbio (ESM/GSM/NSC): EOL Ok
Drive Train Control Node (DTCM): EOL Ok
Climatizador de ar (HVAC/NCL): EOL Failed
Direção Elétrica (EPS/NGE): EOL Ok
Sistema dos freios (ABS/BSM/NFR): EOL Ok
Nó Air Bag (NAB/ORC): EOL Ok
EXECUTING ADJUSTMENT...
Tire pressure monitoring system (TPMS)
PROCEDIMENTO ALINHAMENTO PROXI
Writing to module: Body Computer (BCM/NBC) SUCCESS!
Writing to module: Controle Motor (ECM/NCM) SUCCESS!
Writing to module: Quadro de instrumentos (IPC/NQS) SUCCESS!
Writing to module: Câmbio Automático (TCM/NCA/NCR) SUCCESS!
Writing to module: Nó Seletor do Câmbio (ESM/GSM/NSC) SUCCESS!
Writing to module: Drive Train Control Node (DTCM) SUCCESS!
Writing to module: Climatizador de ar (HVAC/NCL) FAILED! - Timeout error
Writing to module: Entertainment Telematic Node (ETM) FAILED! - Timeout error
Writing to module: Direção Elétrica (EPS/NGE) FAILED! - Timeout error
Writing to module: Sistema dos freios (ABS/BSM/NFR) FAILED! - Timeout error
Writing to module: Nó Air Bag (NAB/ORC) FAILED! - Timeout error
FALHOU A EXECUÇÃO
