fiat 500x 2018 anterior pdc
Poisson
Post by Poisson »
Hello,how can i active anterior pdc in fiat 500x 2018?i have only genuine cable harness on anterior bumper,but i think i have to set up ecu pdc that manage anterior sensor,because rear ecu manage only 4 sensors in rear bumper.
alessandrosx
Re: fiat 500x 2018 anterior pdc
Post by alessandrosx »
hello to install the front parking sensors, you must first change the sensor control unit, with a control unit that also supports the front sensors and connect everything as per the original diagram
rosnik
Post by rosnik »
alessandrosx wrote: 04 Mar 2020, 18:55 hello to install the front parking sensors, you must first change the sensor control unit, with a control unit that also supports the front sensors and connect everything as per the original diagram
can you please post the original PDC diagram?
Tnx
