Allied MY97 Airbag connection time out
Posted: 11 Apr 2010, 15:24
Hello, i try to connect to Allied My97 Airbag (3 pin), but connection is timed out. I use VAG KKL USB interface with multiswitch for switching the pins and i can connect to Engine (7pin) and ABS (1pin), but with Airbag does not work.
I connected with airbag on Alfa 166 with TRW centrallina and all is ok, but connection to Allied on Alfa 156 is imposible.
My Alfa 156 is with 2xAirbag. Front on steering wheel and front on passanger. When i trying to connect i select 2F+2P airbags, but does connect.
Where is the problem?
